Miscellaneous items
dustoff440
central fl
Need cash to finish my Dart!! Make on offer in a PM
A body: sleeves, tie rod ends, new but crusty
drop steering link used to clear V8 oil pan was on a 70 Dart V8
line loc with microswitch SOLD SOLD
magnum front timing cover
750 holley carb body absolutely clean inside and out CARB BODY ONLY
tranny/oil cooler w/ fan that works
Dart window regulators, excellent !!!!!!!!!!!!!!!!!SOLD!!!!!!!!!!!!!!!!!
65-72 all a bodies with 10 inch front brake drums new, slightly crusty SBP SOLD SOLD SOLD
Original A body SBP 8 3/4 Drums run for a few thousand miles after last cut, ready to clean up and bolt on. Existing drum surface very good, resurface not necessary. Do not know if there is enough meat to cut them again !!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!! SOLD!!!!!!!!!!!!!!!!
Magnum manifolds 1 7/8 outlet
Whats the story on the 750 Holley? Vacume or mechanical secondarys, double pumper? Need a rebuild or ready to run, and what are you looking to get for it?
Butch
CARB BODY only 750 vac sec 15 bucks plus ship
line loc sold
regulators sold
new drums sold
made 300 hp and 420 ft lbs torque with M1 lowrise dual plane, headers, and 750 holley not a high rpm but gobs of torque
That trans cooler with fan would make a excellent rear heat/defrost, especially for a vert where scratching that rear glass is not an option.
Does the fan run quietly ?
Fairly quietly, you might possibly hear it when stopped but I think road noise when moving would down it out. 20 plus shipping
