straightlinespeed
Sometimes I pretend to be normal
Hi guys, Im gathering parts for a rewire job on my car and I want to buy some connectors for the steering column and other areas. My worry is that the amp rating on the connectors. I have no idea how many amps are going to the ignition switch when you turn the key to start the car and I want to make sure that the new connectors I get dont burn up and fuse together like the originals did.
I have a catalog that has all the various connectors in them like stated above that has amp ratings for the number of wires in the connector. For instance a 9 wire Molex connector is good for 9-12 amps. Depending on the metri-pack connector it ranges from 14-46 amps. Now Im not sure if that is per wire or the entire connector, it does not specify.
Some of you have recommended the Molex, others the metri-pack. Im mostly only worried about the steering column connection, because it looks like the rest of the car uses the 56 series connectors and I will reuse the connectors that are still good. Just seeing these numbers in the catalog got me thinking and I want to be safe and not burn my car down.
