Once again, you prove how little you know.Yeah but there not much part options like there is for the LA's.
...and I'm not saying that trying to insult you. We all had to learn it sometime. There's plenty of parts for Magnums.
ok. Have fun. You keep digging the hole of ignorance. We're trying to help you here, but you have to let us. You're not. So, cya.Technically if wanted to spend less options on money then I have to get a Chevy 350 which is cheap to build. Being that not an option yet 2 Mopar 318 engines are gonna have to do at the moment.
I know from what I learned from other Mopar guys.Once again, you prove how little you know.
Find new Mopar guys.I know from what I learned from other Mopar guys.
Yep see you later thenok. Have fun. You keep digging the hole of ignorance. We're trying to help you here, but you have to let us. You're not. So, cya.
Simply not true.Yeah but there not much part options like there is for the LA's.
If you don't want a 318 or 360 MagnumTechnically if wanted to spend less options on money then I have to get a Chevy 350 which is cheap to build. Being that not an option yet 2 Mopar 318 engines are gonna have to do at the moment.
No offense but everyone and their brother uses an LS, Coyote, Hellcat's, and 360 Magnum's I don't want what everyone and their brother builds. Mopar 318, 340's, and 360 LA's, 400's, 426 Hemi's, 440's, Chevrolet 350's, 383 Strokers, & 454's, Ford 302's, 351W &C, FE's Ford 429's and Ford 460's are my go to engines. Not sorry but I stand on that.If you don't want a 318 or 360 Magnum
Maybe your better off with a LS from a truck. Way better than a 350........
The point is I don't need to be like everyone and their brother.do you know why everybody and their brother uses those motors?
also, [list of common engines] are your go-to engines? what do you mean by that?
Being different is one thing. Doing two things wrong thinkng it makes a right is another.The point is I don't need to be like everyone and their brother.
We all have the ability to enjoy engines that we like.
Yeah so am I as I am done thinking I need to explain why I chose the Mopar 318 LA. Again peace outBeing different is one thing, thinking doing two things wrong makes a right is another.
I am done here. Have fun
Yeah so am I as I am done thinking I need to explain why I chose the Mopar 318 LA. Again peace out. Maybe you guys can force your 5.9 Magnum's, LS, Coyote, and Hellcat engines on someone else.
look man, you don't know me from the man in the moon but i'm honestly trying to help you here.The point is I don't need to be like everyone and their brother.
I sent you a message.Question on the parts, again. Did main caps for the white block come with it? And what brand are those rods? They look like good pieces. Being that this is all custom work, it’s possible the previous builder has ground the big ends of the rods to .925 width from .940 (.0075/side) and had the big ends honed out for 2.1 to 2.125 bearings (.0125 per side) which would allow using LA Mopar rod bearings after dressing the tang registers depth back in. It would be worth measuring them with the dial calipers to see if they have been modified in that manner. I don’t hate the idea of your using parts for a drag only kind of build, but I would want to sonic check the cylinder thickness above the cement. If you wanted to put an all Chrysler rotating assembly in, then here are your pistons for high compression with enough valve pocket for whatever cam you decide on.
KB KB399KTM.060 KB Performance Hyper Piston and Ring Kits | Summit Racing
You didn't choose a 318 LA. You chose someone's pile of left over parts that is mismatched junk. You've got probably 150 collective years of experience here in this thread telling that you are making a mistake. It's not about the 318. They're great. It's about your parts. Good luck with it. You're going to end up just like that youtube guy you're following along and end up with a bunch of broken junk, instead of just junk.Yeah so am I as I am done thinking I need to explain why I chose the Mopar 318 LA. Again peace out. Maybe you guys can force your 5.9 Magnum's, LS, Coyote, and Hellcat engines on someone else.
Don't forget the counterweights. Can the 360 crank fit the 318 block with stock sized counterweights? I don't believe so, if memory serves me right, so there's more money.look man, you don't know me from the man in the moon but i'm honestly trying to help you here.
undertaking a build like this is daunting even for those of us who have tread that rocky path before. i like wacky **** and i've certainly built my fair share of it, but even this *waves hands vaguely* screams of bad news on every level.
if you really want to forge ahead with this understand that you'll need three things: a friendly relationship with a competent machinist, intimate engine building knowledge and a pile of money.
this isn't just something that "comes together" because "so-and-so said they did [blank]" back in the day. don't believe me? tomorrow's monday, ring up a few machine shops and ask how much to cut a 360 crank down for 318 mains and chevy rods, and to balance the assembly. the responses may shock you. hint: nobody is gonna wanna do it, and those that will are going to want an absolute MINT to do so.
if you're dead set on using that 318 block, go get you a 390 stroker kit for it. a street/strip assembly will run you about 2K and a more competition version is about 2500. that'll put you in a much better position than any homebrewed bullshit chevy rod custom piston nonsense.
The oem LA 3.58 stroke crankshaft counterweight definitely won’t clear the piston skirt of the 318 slugs.Don't forget the counterweights. Can the 360 crank fit the 318 block with stock sized counterweights? I don't believe so, if memory serves me right, so there more money.
block fits fine, it's the pistons that interfere. and with aftermarket pistons it's a who knows guessing game. i know with "stock" pistons it's something like .125~.2 off the counters-- but only 6 of them? i think. it's been... awhile...Don't forget the counterweights. Can the 360 crank fit the 318 block with stock sized counterweights? I don't believe so, if memory serves me right, so there's more money.
He should contact Uncle Tony be right up. His alleyYou didn't choose a 318 LA. You chose someone's pile of left over parts that is mismatched junk. You've got probably 150 collective years of experience here in this thread telling that you are making a mistake. It's not about the 318. They're great. It's about your parts. Good luck with it. You're going to end up just like that youtube guy you're following along and end up with a bunch of broken junk, instead of just junk.
