Mopar P4876074 mechanical pump (Info needed)
SS Lancer
North Carolina
This is Circle track pump I believe but I can't find any specs within my Vast collection of Mopar information !!
Pump has large AN fittings inlet & discharge of pump maybe someone has specs etc ( Carter - USA ) on pump body but new in Mopar box thanks.
This is from a past for sale post by moparvinny. No stats but..
I have a brand new Mopar Performance high flow fuel pump. I purchased the fuel pump for my 340, but the bosses on the stock block (date coded 1969) interfered and I did want to grind them off. Therefore, I'm assuming they are for a 340 race block (or post 69 block)?
Part number: P4876074
Where do you find this stuff? ....and gimmie that chrome box. lol
Brand:
Mopar Performance
Manufacturer's Part Number:
P4876074
Part Type:
Fuel Pumps
Summit Racing Part Number:
DCC-4876074
Fuel Pump Type:
Mechanical
Flow Rate:
120 gph/454 lph
Fuel Pressure (psi):
7 psi
Fuel Pressure Regulator Included:
No
Sending Unit Included:
No
Fuel Pump Inlet Size:
1/4 in. NPT
Inlet Quantity:
1
Inlet Attachment:
Female threads
Fuel Pump Outlet Size:
1/4 in. NPT
Outlet Quantity:
1
Outlet Attachment:
Female threads
Gasket Included:
No
Wiring Harness Included:
No
Mounting Bracket Included:
No
Mounting Hardware Included:
No
Pulley Included:
No
Quantity:
Sold individually.
Notes:
NASCAR truck approved.
This has a # 8 inlet # 6 outlet
Guy on ebay is selling them I bought
3 yesterday offer $165 shipped he will take it !!!
It has a #8 inlet and
#6 outlet I believe didn't have time to verify 100% but pretty sure
Chevy pump (Identical) specs
Sorry #8 inlet
#6 outlet wanted to correct my previous comment.
Brand:
Mopar Performance
P4876074
Part Type:
Fuel Pumps
DCC-4876074
Fuel Pump Type:
Mechanical
Flow Rate:
120 gph/454 lph
7 psi
No
No
1/4 in. NPT
Inlet Quantity:
1
Inlet Attachment:
Female threads
1/4 in. NPT
Outlet Quantity:
1
Outlet Attachment:
Female threads
Gasket Included:
No
No
No
No
Pulley Included:
No
Quantity:
Sold individually.
Notes:
That's as good as you get.
from that it's likely a Carter M6902 which also advertized a 120 gph free flow.
I don't know if Ryan Brown is testing pumps anymore. I would have sent him more at the time but only had the three to test.
Yep, I saw the graph and noticed no stats for the carb that the op had questions about. Great information there.
