[SOLD] Mopar Performance solid cam kit
coloradohill
Northern Colorado
I have a NIB small block Mopar Performance solid lifter cam and lifters kit for sale.
Purple shaft P/N P4529973
Specs are in the photos.
Asking 425 shipped in cont. U.S. from 80534. Will ship outside the U.S. for difference of actual shipping cost.
Tempting… but what kind of compression and heads would this require? Trick flows be okay? 10:1 or more?
4 speed with 3.90 gears be okay? Or more?
The trick flows with 10:1 would be fine especially with a 4 speed
and 3.91 or more. I always used the Oval Track Cams because they
had a closer lobe center providing significantly more midrange torque
at only the expense of a bit less vacuum at low RPMs.
Now most of the Cam Manufactures have caught up and closed their
lobe centers.
Back then I could not convince Mopar Perf. hence I used Oval Track
cams exclusively and very seldom lost a Street Race (How I made my living).
I bought this from GTXJohn several years ago and decided to go with a roller.
I bought the same kit from him also probably around the same time / it's seasoning like a bottle of fine wine !
One thing for sure that USA grind will never be offered again because the Chrysler we
Knew is gone.
