[WANTED] mopar pilot bearing
Hard to believe they are discontinued. I'd try NAPA or local parts store by application (1988 Dakota V6 5 spd for one example) rather than using specific SKF part #.
I can get oil lite bronze, or oil lite bronze w/PTFE, I have to check the size I think there 3/4" id 1" od but not sure till I check.
Does anyone have the size of the bushings?
Are you needing the one that is undersized? If you need the regular ones I have two or three of them floating around. If you crank is new enough that the needle bearing will fit....I would use that. My 65 273 crank in my 340 the torque converter register is too small for the needle bearing....I forget what year they changed that.
Kim, Can you measure the id, od and length of the bushings I have access to a ton of bushings.
I think they are .750 id, .9400 od and 1.000 long but not sure.
Thanks
Brian
