joshua dewitt
hey guys, any one ran the old mopar performance p4452782 factory muscle car reporduction camshaft and lifter pkg. 268-276-44degrees. valve lift .429"/.444" on a center line of 114degrees. says idle to 5000rpm... it's new in the box....
i have a 318 going to run a .30 over with zero deck pistions. run the factory 318 head until i get better one.. possible 302's? have headers , and a998 lock up off a toggle for hwy only out of a 78-80 rwd car. . and plan to eventually run 3.23-3.55 gears...want a strong street machine with ocasional stop light hot rod , will have p/s , p/b and a/c...should i advance the cam for more idle lope? any thoughts.... never delt with the factory purple 340 cam before.... any links to a sound bit on the idle quallity? i would really like to know how this cam idle sound would be any lump to it?
i may have been talked out of the hughes whiplash cam. (love the sound but need daily driveabile.) would a voodoo cam work better? i have used them in small block chevys wiith good results. also plan on a dual plane air game intake for the looks and perfomance... any takers out there? just becoming a mopar boy. came from ford land....
