I have the mopar thin head gaskets on my motor right now but I am installing rhs/indy heads one of these weekends when I don't have to work. Should I install another set of mp thin head gaskets again? Or just use the standard rebuild kit head gaskets, I think there like .040 but not sure. I have read the rhs heads will bump up my compression, and I have had the heads, spring pressure set up for the voodoo 60403 lift. I did'nt know if the thinner head gasket would effect the spring pressure enough to matter or not. I am hoping to have a problem free cam break in. The engine is a 318 bored .040 over with a scat 4 inch crank and 847 dish icon pistons. I also plan on using stock valve train, for now. 1.5 stamped steel rockers.
