johnmucci
moparmucci
just got this 65 dart gt vert 273(non-hipo) 4 speed...several questions once again to educate me
.1 the transmission has one drain plug on the left side...the passenger side has an upper plug I am presuming that is the "Fill" plug correct?? so what tranny is in it???
2. It has a vibration at 0-30 that shakes the car bad....in any gear...once you get past 30mph it smooths right out...I bought 4 brand new tires, still did it, guy said u joint was bad, replaced that as well, still does it any ideas?
3. Had the frt suspension checked cuz there is a lot of "play in the steering wheel"....guy says the steering shaft is moving in gear box.....whats the cure??? i stop here for now....any help would be great thanks, John
