lets see what your working on. the more the merrier.
Brace yourself...my living room is a mess right now due to the project.
Staircase was made from rough cut slab wood. Trimmed, sanded and stained to what you see now. The cat did nothing, it's lazy but claims all credit for the job.
Closet door (in the mock up/test fit stage) has no door knob and will feature a hidden release mechanism, hidden in the End Post of the Railing on the Staircase. Replacing the top portion of the End Post (wooden pyramid) with a Brass End Piece salvaged from an antique fireplace, which will serve as the "Door knob" for the closet.
Closet door and staircase will be one massive bookshelf that will wrap around to the other wall and encompass my TV, Surround Sound system, Audio Equipment, Media Library (VHS, DVD, CD, Cassette, 8-Track, Vinyl and Games)
All of the closet pieces (minus the framing for the door & door itself), shelves, etc will also be rough cut slab lumber that will be finished similar to the staircase (only in a darker stain).
I just need to go load up my Router, my grandfather borrowed it for a project and now I'm at a standstill until I get it back.
My next two projects after the Staircase & Bookshelves will be to make some goodies to raise my Projector into the ceiling (when not in use), same goes for the 180" Projector Screen too. That way they're not taking up space all the time.
When that's done, I'll be moving on to the kitchen to build a large Bar, with Taps and a Double Layer Shelf design (one shelf in front of another, with the front shelf capable of being lowered into the bar counter top to access the shelf behind it).
I foresee lots of Linear and Rotary Actuators in my future, for those projects.
