71Duster
Here is my current combo, it's a street driven car and full bodied etc. I don;t want any steeper gears then I currently have. I'm looking for more power by tweaking my current combo. Contemplating cam changes and or Edelbrock heads but not sure if there are enough gains with the heads on a mild application.
Thoughts and opinions?
650 Speed Demon mechanical secondaries, on an edelbrock rpm intake
Stock J Heads 2.02 intake 1.60 exhaust and Crane Gold 1.5 ratio rocker arms.
3.55 gears and a 727 with 3000rpm SMR Convertor- stage 2 shift kit from transgo.
It runs a Hughes cam #heh2328al
111deg lobe seperation/installed centerline 108deg
intake lift .506/ exhaust .524
[email protected] Intake223deg/ Exhaust 228deg
Engine is .060 over with Keith Black Hypereutectic pistons on stock rods and a stock forged crank.
Ignition is an FBO box
Distributor was curved by Dave's Mopar in Calgary to these specs.
TTI Headders with an x-pipe into Dynomax Ultra Flows.
