Motor mount brackets
Bgdude1
Midwest
I am using an X block for a 408 build, what brackets should I purchase to install in my 72 duster? I see solid mounts should work regardless. Do I purchase 318, 360, 340? Please advise. I prefer mounts over motor plate.
For $300, I can purchase A body 318 upgrade and A body 340 upgrade from Mancini.
The driver side mounts are different between the 273/318 and the 340/360 and the passenger side are the same.
The X block uses 318 mounts so the different on the drivers side.
What do I need and does anyone have them?
To be honest with you everybody's done modified their driver side 318 brackets to make them work on a 340
I have a 340 in my duster, 72, that is coming out, can I use the brackets and mounts, just modify for the X block?
Copy this photo and weld it. Bam. 318 driver mount is now a 340 or 360 mount. Cost? A scrap piece of metal to Copy the other side of the mount as a template.
I have the ones you need...you only need driver side...Mancini has the solid mounts to go on it
