mounting ears - 5.9 5.2 any differences
lilredridinghoo
lower saxony
just sitting in the office, and it pops up in my mind... maybe a stupid question:
- is there any difference regarding the mounting ears on 5.2 and 5.9 magnum blocks ?
i´m asking because i will avoid to run into problems when swaping my 273 out and putting the 5.2 in
so the question cld also be: are LA 273/318 mounting ears equal to 5.2 magnum block ears ?
As far as I know,none Mr.Red Hood.. The engine was designed to be in trucks only,think LA 360, or 318 La mounts,shimmed with washers like LA 360 swap would need.
short update...
driver side: if you have an early a-body mount you can use it, i only needed a 0.075" washer
passenger side: the magnum block has different ear lobes compared to a 273/318 LA-Block, so lower lope on the rear is missing and instead of that, it has one on the front side.
so you have to modify the bracket - first i mounted the orig. bracket and made a cardboard template from the missing section/part
then copied it with some metal parts laying around and bolted it onto the orig. bracket. to make it a bit more stiffer i welded all the pieces together
