mp brake kit.
needsaresto
O.K check this brake kit out.
http://www.mpbrakes.com/products/product-detail.cfm?product_id=241
Now,I would be going from manual drum to this,but using parts I bought used some time ago.All my brake stuff is factory original.I have calipers,spindles,bearings,seals, pads,rotors,booster, master,valve,lines,brackets,shields,ball joints,even the linkage.Basically everything except for the correct rims.All the rims I have are drum brake rims.
I was reading the new mopar enthusiast and the article on mp brakes kit caught my eye. But the control arms getting swapped confused me.
Wont disc brakes bolt up to the control arms I have? The claim is made that all master power brakes parts are factory original.
If they do,why are they in this kit?
What control arms do you have?
If you doing the conversion to 4 1/2 bolt pattern then you need upper control arms from 73 - up a body. You need the bigger ball joints that is why you need them.
Ahh,maybe thats what I missed then.
I will be using the original control arms from my drum system.My brake system will stay sbp.
