MSD Blaster 2 coil
Ken coils are misleading especially "universal" ones. GM like .3, ford is like .7 I think, Most mopar is 1.5 Have to do the research on them. Blasters come in all of those ratings, then get into say MSD etc gets confusing fast
One was a kit. coil and 0.80 resister. Should I switch to 1.50 to protect ecu?
It's this one with 0.80 resistor. I thought that was recommended. Your saying 1.5? THX
MSD Ignition 8200MSD MSD Blaster 2 Ignition Coils | Summit Racing
Standard doesn't say what resistance. Would this be a 1.50 ballast?
1974 DODGE DART 5.9L 360cid V8 Ballast Resistor | Shop Now at RockAuto
The MSD 8200MSD, or 8200, ignition coil has a 0.7 ohm primary resistance. With a 0.8 ohm resistor, and assuming ~12.5 volts DC at the Ignition RUN circuit, with the 8200 coil, static current through the switching transistor of the electronic control unit (ECU) will hit 8.3 amps. 8.3 amps will push the limits of a stock production Chrysler ECU, and exceed the current carrying capability of modern aftermarket ECUs leading to overheating and possible failure of the ECU. High Performance ECUs such as the Mopar Performance/Direct Connection P4120534, P4120600, or P3690256 can handle more current.
As a "rule of thumb", for the Chrysler ECU system, strive for a combined total resistance of the coil, ballast resistor, wiring, connections, and effective transistor resistance of two to three ohms total at 70-80 degrees Fahrenheit. This limits the ECU switching transistor and coil primary current to about four to six amps peak. Although the transistor can actually sink more current in earlier Chrysler high performance and production ECUs,as well as earlier aftermarket ECUs, this conservative current level is easier on ECUs while still delivering adequate spark energy to the spark plugs.
If not using a stock or stock replacement coil, an Accel 8140, 8140C or Mallory 29219 ignition coil is a better match to the stock style Chrysler electronic ignition system. However, to keep the MSD 8200 with a stock type ECU, increase the value of the ballast resistor as earlier advised. Use a 1.2 - 1.5 ohm ballast resistor instead of the 0.8 ohm resistor.
The following table summarizes select ignition coils with resistance values.
NOTE: Listed coils are oil filled canister type unless otherwise noted.
BrandPart NumberPrimary ResistanceSecondary ResistanceNotes
Accel8140 Super Stock
8140C Super Stock
1.4 ohms9.20K ohms8140 = painted
8140C = Chrome
Accel8145 Super Stock
8145C Super Stock
0.7 ohms10.80K ohms8145 = painted
8145C = Chrome
Accel1400010.7 ohm11.80K ohmsSuper Coil. Supplied with a 0.8 ohm ballast resistor.
Accel1403060.2 ohm7.3K ohmsChrome “Racing Coil”
Borg WarnerE-621.4 ohms14.6K ohms‘406’, epoxy
EchlinIC55000.7 ohm11.80K ohmsSupplied with a 0.8 ohm ballast resistor. Same as Accel Super Coil.
FilkoEP21.4 ohms14.6K ohms‘406’, epoxy
Kem312A1.4 ohms14.6K ohms‘406’, epoxy
Mallory294400.6 ohm11.3K ohmsNon-canister shape. ProMaster
Mallory292191.36 ohm10.87K ohmsChrome
Mopar PerformanceP36905600.2 ohm7.3K ohmsBlack or Chrome “Racing Coil”
Use 0.25 ohm ballast resistor for racing. Same as Accel 140306.
Mopar PerformanceP41208890.7 ohm11.80K ohmsSame as Accel Super Coil.
MSD82000.7 ohm4.50K ohmsChrome. 0.8 ohm Ballast resistor required for points.
MSD82020.7 ohm4.50K ohms0.8 ohm Ballast resistor required for points.
MSD820230.7 ohm4.50K ohmsBlaster 2, black,
MSD82030.7 ohm4.50K ohmsBlaster 2, chrome. Supplied with a 0.8 ohm ballast resistor. Ballast resistor required for points and Mallory Unilite.
MSD82220.7 ohm4.70K ohmsBlaster 2, black, epoxy, high vibration, 0.8 ohm Ballast resistor required for points.
MSD82230.7 ohm4.50K ohmsBlaster 3, red, tall tower, 0.8 ohm Ballast resistor required for points.
SorensenSC-29X1.4 ohms14.3K ohmsMagnition, epoxy
Depending on the wired system, to assist with 1.2 - 1.5 ohm ballast resistor selection using original or stock replacement ballast resistors, the following table lists part numbers for both four terminal dual ballast resistors and two terminal single ballast resistors resistors:
Part NumberAftermarketTerminalsOhmsNotes
3874767
  • Standard RU-12/RU-12T
  • Niehoff AL125BCM, AL125B
  • E-tron RU-12
  • Echlin ICR 24
  • GP EL-401
  • Accel 150351
  • Filko CH400
  • Auto-Tune E-221
  • E-tron RU12
  • Sorensen CE-3
41.25/5
4106140, 5206436
  • Wells CR-107/CR-1107
  • Standard RU-11/RU-11T
  • WVE 6R1007
  • Airtex 6R1007
  • Filko CH401
  • Niehoff AL125C
  • E-tron RU4
21.25No metal strap.
Some listings show 5206436 as 1.0 ohm. Others show it as 0.7 ohm. Actual measured value is 1.2 ohm.
NOTE: Actual measured resistance values are not always consistent among part numbers and brands even within a brand's own offerings. Double check all resistors to ensure the value is as desired for the ignition system.
Additional aftermarket resistors are listed in the following table for further direct resistance value selection with resistors not specified as direct Chrysler replacements:
BrandPart NumberResistanceNotes
Jegs555-401031.0 ohm
EchlinICR231.2 ohms
StandardRU-231.2 ohms
Accel1502501.35 ohms
EchlinICR111.35 ohms
StandardRU-41.35 ohms
EchlinICR341.4 ohms
StandardRU-371.4 ohms
Accel1501501.82 ohms
Moroso723901.82 ohms
For more general information about the Chrysler electronic ignition system, see the following:
