I just got this to try it out and see how things work and go. But I noticed the instructions are not just vague, it’s closer to reading instructions for a different distributor all together. Making notations to set up the distributors vacuum advance using letters A through T with no letters present on the distributor.
In the initial set up the instructions say to set the rotary switches to 1 & 7. Which in is which and where the arrow to point where it’s set at?
Same for RPM limiter.
