OK, So am hooking my MSD 6AL up and so far I ran the orange and black harness to my MSD coil. Then I have a heavy black and a heavy red which instructions say Red to positive battery and black no negative battery. Am I assuming these actually go on my solenoid next to the battery?? Then the gray is for a tach (autometer) which I have in the dash. That leaves a small red which I understand gets spliced together with the two ballast resistor wires when I eliminate the ballast resistor. . I also should say that I am running an MSD ready to run distributor. So I understand I am to dispose of the mopar orange box and dispose of the ballast resistor. Onboard wiring is a 72 Demon 340 car.
