805moparkid
Slant and AFX Guy
If I understand you right you've a high speed DSL from the phone company and you want to use it to monitor the solar panels and for internet access to two computers. If this is your plan get a wireless router. It will have one input that you will connect to the DSL modem output. The wireless modem should have 4 ethernet outputs. You'll connect CAT 5E to that and run to the back of you're computer and plug that into the NIC card (network interface card) It looks like a large telephone jack. If you cannot get the ethernet cable to the computer buy a wireless card for the computer and set up a wireless link to that terminal. Follow the instructions from the wireless router. Ethernet cables have 4 pair of wires. A blue/ white pair, a orange/white pair, a green /white pair and finally a brown white pair. You cannot run dialtone through them if you're using it for data. You can buy them from computer stores in different lengths but make sure they know that it's for a network. I have a 100 ft piece here, it was cheap. You should be able to plug in the two computers and the solar panels to the wireless and still use the wireless with no problem..
now thats more along the lines of what i was thinking...
