[WANTED] multiple items, engine, trim, etc
Durney
Michigan
Looking for the following :
3671587 Heads bare (no bad core shift or cracked junk)
3671918 Intake
6318 thermoquad
Stock 340 oil pan (for 73 duster) and windage tray
Stock correct 73 valve covers
73 340 air cleaner
3515734 bellhousing and fork
3656771 distributor (no worn shafts please)
Heater hose support bracket
Correct 26" ,manual trans , radiator shroud
E-brake handle
Hood release assy (handle /mount/ cable)
73-76 tailight bezels (Preferably mint/like new but not 400$...i know, good luck.)
All three Duster emblems
Crank pulley (with power steering)
Pm or email me with what you have and if you have pics, Thanks folks!
I have a set of the 587 heads if you still need them.
Ken
Edison, NJ
Mancini racing ? ............Got lube and a platinum card ? WoW !
Keep an eye out in the parts/parts car section.
3671918 Intake
6318 thermoquad
73 340 air cleaner
E-brake handle
Think I have at least 2 of your emblems, maybe all 3. All cleaned, shined and re-painted. $25 each. Part #'s??
I have an e-brake handle, heater hose bracket & correct 2 groove crank pullley for a 73 340 which is one year only. PM for pics and more info
3671918 Intake
6318 thermoquad
73 340 air cleaner
E-brake handle
Updated list
looking for the following
6318 thermoquad
stock correct 73 valve covers
73 340 air cleaner
heater hose support bracket
correct 26" ,manual trans , radiator and shroud
hood release assy (handle /mount/ cable)
73-76 tailight bezels (preferably mint/like new but not 400$...i know, good luck.)
all three duster emblems
crank pulley (with power steering)
pm or email me with what you have and if you have pics, thanks folks!
Hello I have air cleaner E brake lever and some other parts I sent a pm Thank you steve
