2sixtynines
Yes, they did a superb job on getting the gaps lined up nicely. Although the hood still had a good size gap they tweaked the header panel and got it lined up really well.some very nice gappige going on there
neil.
neil.
Yes it is.As they say: It’s the prep work that make a great paint job!
NiceWhat stage of the restoration are you at? Obviously, I see the last date appears to be Jan 2008
That line is difficult to see in the quarter and fades away. When they did the block sanding on my car I made sure they knew it was there. They put tape above the line and sanded up to it; then put tape below the line and sanded down to it. This way they did not diminish, move, or erase the body lines in the process. There is also the line on the C-pilar on the notch that is a little more obvious.The sixth pic with the arrow in it shows the crease in the quarter. I have only seen a couple 67-69 barracudas with this crease although it is supposed to be there. I was amazed to see that whoever did this at the first body shop knew it was supposed to be there. Having built and purchased a lot of Barracuda model kits and knowing they have this crease, I almost have to assume the body man may have been a modeler as well.
Yes it is difficult to see. You almost have to be looking for it to notice it. I have the lower body stripe which makes it less noticeable. By the way, nice car.That line is difficult to see in the quarter and fades away. When they did the block sanding on my car I made sure they knew it was there. They put tape above the line and sanded up to it; then put tape below the line and sanded down to it. This way they did not diminish, move, or erase the body lines in the process. There is also the line on the C-pilar on the notch that is a little more obvious.
I used to have a '68 Barracuda convertible over 30 years ago. I always thought something was off. When I started stripping multiple layers of paint and bondo I figured out that they had shifted that body line on the fender, door, quarter up an inch or more in the process of mudding the car with bondo. It was almost Camaro-ish.
Thanks. The body man did some really fantastic work. The painter did a great job as well. Was his first time doing single stage.
