my 340..3 cars, 34 years, 1 family. where to go from here
If the head has all of that corrosion on one cylinder, why none on any of the others? Seems to me that maybe .060 is too far for that block. (Not used to seeing an LA block taken more than .040 over.) Suggest a Magnaflux of the cylinder in question. Otherwise, all the cams in the world won't make better power. 2¢
If the valves were open over that cylinder, wouldnt that be the reason that cylinder was affected and the others were not?
Yes. Condensation is a sitting engines worst nightmare.
I agree that .060 might be a little far. You could have the cylinders sonic checked for thickness, worse case you put a sleeve in it.
I run a .060 340 in our Demon with no concerns, it was originally a street car engine, but is on it's second full race season.
It is a mild build, KB replacement pistons, stock rods/crank, MP solid cam 528/284 & ported 80's model head castings. Shift @ 6500.
8" convertor, 4:30 gear, & 9X28" slicks.
Best 1/8 mile 6.96 / 1/4 mile 11.20 with 60ft range 1.48-1.52
Very nice! I spoke to a local machine shop and it was a very impressive shop, owner gave me the full tour and showed me his equipment, machinery, motors hes working on. I think I will sleeve that cylinder, and go from there.
I think I see your point. The likelihood that only one cylinder would have a valve open and three other cylinders with closed valves would be nil. There are 4 cylinders on the bank with valves at some point of activation, unless there are three cylinders in the "power" stroke at once. The more overlap the cam in the engine has, the more pronounced this should be. Not likely there would be just one cylinder with an open valve. This is what causes me to question the integrity of the water jacket around that particular cylinder.
The 340 in my Duster is .060" over and has no issues, actually ran cold with a mechanical fan. I have heard of a couple going .080" over and still sonic testing just fine. They're the exception and not the rule, but .060" over should be fine unless thats a particularly poor example of a 340 block.
I'd suspect a head gasket well before I suspected a water jacket on an engine that's only .060" over.
Plus, there's more at work than just open intake valves. And usually, it has to be an intake valve to get water into the engine unless the exhaust isn't hooked up. Intake runner design, single vs dual plane intake, how well the butterfly's in the carb fit, and even whether or not the car is sitting level all can play a role in water getting into one cylinder versus others. One flat tire on a car that's sitting will direct all the water to the cylinder with the open intake valve closest to that corner.
Just to be clear to guys, the motor was out of the car and on an engine stand for a few years. No exhaust hooked up no carb.
And no water in the water jackets either. So the water damage is just from whatever it encountered during storage.
With everything that's happened to that block, and the fact that's its sitting at .060" over, I would have it magged and sonic checked before I spent too much money on it. If all the other cylinders are fine, then sleeving the one with damage is no big deal. But I'd want to make sure the other cylinders are fine first.
Yup, thats exactly what im doing on tuesday.
