oliver
I just got around to calculating my actual static and dynamic compression ratios, looks like ill be sitting right at 10.42 static compression and 7.61 dynamic.... i thought the dynamic compression sounds a little low but i checked and rechecked things and it all computes like that.
Little info about the motor, 4.1" bore, 3.31" stroke, 68cc J heads, kb243's .026 out of the block, 7.5cc reliefs, 4.140 bore and .028" thick head gaskets, 6.123" con rod, 288 duration cam, 110 lsa.
Think this combo will run on 91 okay?
