Bill Crowell
It's a factory stock 360 with a ThermoQuad that was running well until the other day, when it started dying at idle. It will idle OK for about a minute when you first start it up, but then it starts slowing down and eventually dies.
In the past, when this engine would start running badly, I would replace the distributor cap and rotor and that would always correct it. I tried that this time, but no go.
It runs well under the carb primary circuit, when you give it some gas. It sure is acting like it's running out of fuel at idle, though, but I'm not sure. The idle quality, while it does idle, is rather poor. But how can it really be running out of fuel if it runs well on the primary circuit of the TQ?
Suggestions for what to check? I guess I should start by replacing the fuel filter, but I'll bet it is OK.
If it were a plugged idle circuit, why does it idle OK at first, and then slow down and die?
Do you think I should pull the idle adjustment screws out of the TQ and shoot some carb cleaner into the holes?
Thanks a lot, guys.
Thanks a lot, guys.
