my calipers are to big they hit on the lower control arm ?
Suspension, Steering and Chassis
  1. 273 ball
    273 ball Well-Known Member
    537
    23
    Mar 12, 2016
    hemet
    Local Time:
    10:10 AM
    Hi I have a disk brake set up I am putting on my 67 barracuda 73 and up and the calipers hit on the lower control arm where the brake line is on the caliper . do they make a smaller caliper , for that set up for a 67 barracuda
    • Thanks! Thanks! x 1
    • jimjimjimmy
      jimjimjimmy lobsterman FABO Gold Member
      4,296
      1064
      Nov 2, 2010
      p. e. i.
      Local Time:
      2:10 PM
      do you have the parts on the right side .
    • 72bluNblu
      72bluNblu FABO Gold Member FABO Gold Member
      9,718
      3916
      Nov 28, 2008
      NorCal
      Local Time:
      10:10 AM
      A picture would be really helpful. Some years of the calipers are not compatible, what was the source vehicle? The spindles can be swapped side to side as well to move the calipers from the front to the back, but the bleeders on the calipers have to be on top either way.
      • Agree Agree x 2
      • Jim Lusk
        Jim Lusk Well-Known Member
        4,095
        488
        Mar 8, 2006
        Fresno, CA
        Local Time:
        10:10 AM
        After looking at a pic of the calipers on a web site, it sounds like you have them on the wrong side. Bleeder and hose should be on the top.
        • Agree Agree x 1
        • Jimacuda
          Jimacuda Well-Known Member
          1,502
          428
          Nov 10, 2006
          Phoenix AZ
          Local Time:
          11:10 AM
          Which type caliper...Slider or pin?
          Had same issue with pin mount calipers.
          Swapping side to side does not solve.
        • 72bluNblu
          9,718
          3916
          Nov 28, 2008
          NorCal
          Local Time:
          10:10 AM
          Yeah, because some years of the pin calipers have the hose in the wrong spot for A bodies. The pin style calipers will work, but only certain versions of the calipers. @hemi71x would know...
        • hemi71x
          hemi71x FABO Gold Member FABO Gold Member
          4,934
          1537
          Dec 22, 2009
          Rancho Cordova, CA
          Local Time:
          10:10 AM
          Sounds like your trying to use 73 up, B body calipers, which you have found out don't work, with clearance issues.
          70-72 B body, 70-74 E body pin type calipers are what's known to be ok for a swap.
