AJ/FormS
68 Formua-S fastback clone 367/A833/GVod/3.55s
- Joined
- Jan 19, 2014
- Messages
- 24,946
- Reaction score
- 12,297
Never saw a Unilug that fit a 4" bc.
What type of wheels did you have powder coated? Steel ? Most mag wheels are centered by the lug nuts not by the center bore and the center bore on mag type wheels have enlarged center bore openings..Word of caution about powder coated wheels, don't powder coat the surface that mates to the hub /rotor or the inside of the center bore if it is used for centering. I had some wheels done and did not think of it. Took forever to enlarge the center bore to fit the hub, and the coating on the hub mating surface can crush or rub away over time loosening the wheel.
seen a set done in big flake chrome on black //had to look 2x NICEWell I think I just decided I need powder coated mags.
This is a pic of the car with the wheels. Once I get the 340 call outs and lower rocker stripes on it I'll have the look I was going for. My Harley has the flash, I need something else on the exterior of this.
Your wheel bearing looks shot!!! -Jed.Folks this is where people who are easily upset should look away..
Be warned its not pretty..
Just say No to drugs!!!
Stock 2006 Dodge Grand Caravan aluminum wheels. They were used and looked better in the photo so I had the blasted and powder coated.What type of wheels did you have powder coated
just me....scoops and the "A12" lite package works// the barracuda had it's own style
I have had many people ask "what kind of mustang is that" then I educate them and telling them when they see a mustang ask the owner" what kinda barracuda is that"
kinda leaning towards this
but in a chrome graphic on the b5 when it is time for paint//I have a buddy that does large graphics
Having a 1 of a few hundred A56's built, externally except for the wheels I'm sticking with the factory graphics and B7 color.just me....scoops and the "A12" lite package works// the barracuda had it's own style
but in a chrome or gold graphic on the b5 when it is time for paint//I have a buddy that does large graphics
with today's modern techniques ie..powder coat,hydro dip,wrapping, dipping and applique graphics it all on you !
changing gearsHaving a 1 of a few hundred A56's built, externally except for the wheels I'm sticking with the factory graphics and B7 color.
Why? What’s wrong with that picture? Unilug. Probably 4 1/2 or 4 3/4 bolt pattern.
I used 7/16-20 with .75 shaft lug nuts. (if it's a stock A body)
I believe graphics and the scoops. Cuda pkg cars had hd sway bar,shocks, 14 x 5.5 wheels but still 5 on 4 sbp. All other options were the same except for the 440 cuda which was only available with the cuda package and no convertible cuda pkg cars.changing gears
what was the difference between the "cuda and the "S" ??stickers ?? the options were many for both !!???
so ,is boils down to the a56 code,340 ,383,scoops,cuda graphics and the wild card 440 M code,the S came with 5.5 red lines,hd sway bar,shocks, 340/ 383,S badges and tail panel//besides the 440 that was a hell of a sales pitch on a short name "CUDA" and the rest is history !I believe graphics and the scoops. Cuda pkg cars had hd sway bar,shocks, 14 x 5.5 wheels but still 5 on 4 snap. All other options were the same except for the 440 cuda which was only available with the cuda package and no convertible cuda pkg cars.
I see something such as this in you future...….Folks this is where people who are easily upset should look away..
340- A56, 383- A57, 440- A13so ,is boils down to the a56 code,340 ,383,scoops,cuda graphics and the wild card 440 M code,the S came with 5.5 red lines,hd sway bar,shocks, 340/ 383,S badges and tail panel//besides the 440 that was a hell of a sales pitch on a short name "CUDA" and the rest is history !
Yep, and the first year that they officially designated a Barracuda as a "cuda"so ,is boils down to the a56 code,340 ,383,scoops,cuda graphics and the wild card 440 M code,the S came with 5.5 red lines,hd sway bar,shocks, 340/ 383,S badges and tail panel//besides the 440 that was a hell of a sales pitch on a short name "CUDA" and the rest is history !
One thing I wanted to do George was powdercoat or "black chrome" the fliptop cap and backup light housings. Give it a slightly different personality.
how about a b5 blue mod top wrap !
Check the Lugnut King for lug-nuts, just tell them the wheels you have and the car the wheels are going on, they will have the right lug-nuts in stock.
Now that's a lightened wheel. Looks like it'll fit everything from a Vdub to a C10.View attachment 1715530602
Some days you eat the Bear and other days the Bear eats you.
