Nick M.
Just picked up a 360, complete carb to oil pan. Casting # 4045601-360 dated 8-11-76. Did some teardow to see what i had to work with, as expected it could use an overbore (currently std dished pistons) as it has a ridge at the top of the bore. Took some crude measurements of deck hieght (feeler gauge and straight edge) and found the piston to be 0.093" in the hole! I know this is not the most accurate method of measurement but wow, is this the common for this era 360?
I plan to use KB-107's on my tight budget rebuild and was hoping to avoid the added expense of zero decking the block, but i am afriad my comp ratio will still be low even with the new pistons. I will be re-using the stock 915-A cyl heads that came on the motor. What can I expect (ballpark) for a compression ratio with an uncut deck? Any ideas how much it costs to zero deck a block? >
