My pass side hood hinge dismounted or unbolted ??
chasb
493”/440
Hobe Sound FL
Can't close the hood now. Looks like something snapped or came off, etc.
How do you fix. Can the hood be removed from the hood hinges so it can be bolted back togetrher or fixed some other way?
Thanks
Depends on what happened. It may have broke the hinge, sprung the hinge, etc.
If you need one side, I have one but not sure which side. The previous owner did a stupid thing and tried to pry the hinge off without removing any clips and bent one up pretty good.
take off your inner splash shield, the hinge is held up by two pins attached to the door structure area, the pins have a push nut same as the trunk hinge, with some help you can get it back together without unbolting the hood unless the hinge broke theres usually some listed on E-bay
did it make a loud bang as mine did that earlier this summer and all it was was the hinge was dry try squirting some oil on them and that should solve the problem it did with mine
