My search for a shorty D100 is over
You’d think after the “great Tucson hot sauce debacle of 25” that I’d lay low a little bit but honestly I haven’t. Still want hot sauce on just about everything.
I was worried myself but I took the risk and so far I haven’t had any issues.
Just a quicky update with (probably) more to come shortly. We’re getting ready for Pomona on Saturday and putting the truck in “race” mode, whatever that means. Oh I know, drag radials are back on, and nitrous bottles are full. I got the nitrous controller all wired up but I’m having problems with the rpm signal,
Where are the N2O electronics experts? Need help.
In case you missed it. I’m building a filter and if that doesn’t work I’ll stick the button back in the truck temporarily. Friday night I have my work Christmas party and usually we party like it’s 1987 so I’m guessing about 2am I’ll be driving the D100 about 40 miles to my girls house. She lives 1/2 mile from the drag strip. I’ll sleep for a couple hours then head to the show. I got the draggy, and the go pro all charged up and hopefully I’ll have some videos with data overlayed to share.
Good luck! I’m interested in the 60’ times you’ll turn. I couldn’t get my lowered D100 to hook. Are you still running the 9 1/4 diff?
I wish. Mine is the stock 6 cylinder 8-3/8. Which is just the truck nomenclature for “8-1/4” weak *** differential”. I don’t plan to hammer it off the line, I'm not trying to rotate the earth by any stretch.
No big deal, you can make up the 60' with good pull through the midrange. You can find 8 3/4 in early power-Wagons. I found one in a 73 W100.
I currently own (3) 8-3/4 diffs. Non of which are wide enough for this truck. I have a good friend with one out of a D100 and I’m trying to pry it from his hands. @jedrattle are you listening?!?
i have one 8 3/4...but would cost to much to carry it across the country
A-bodies have the same perch width... then get some really deep dish rims :)
That’s kinda the problem. I have wheels and tires I really like. Don’t want to buy another set. So I need 64-7/16” wide wms to wms.
Aren't C-bodies or E-bodies really close? Can't remember....
72-74 D100 8 3/4 is 59 7/16 flange to flange on the bare housing. 70-74 C body is the same width......just gotta redo the perches where you need them.
what about '65-71 Dodge trucks?? Aren't they the same as well? I just bought a dodge truck 8.75 for our truck without knowing, everything was the same width as the 8.25. I dont' know what year of rear I bought though, it was laying on the ground
Here's the whole chart. A friend of mine put a C body axle on top of the springs when he lowered his stepside. It fit perfect.
so the '65-71's would only be a half inch narrower per side. Wouldn't even notice if a wider tire was used in the back
I've got a 68 8 3/4 truck housing I'm gonna stick up under my 88 D100. spring perches are same width as the 9 1/4 under the 88. It will be a bolt in if I don't break the U bolts getting the 9 1/4 out...lol. I have 5 on 5 axles for the 8 3/4, so I can use brakes and wheels right back.
Thats what I have
I know the spring perch is different
Or at least the frame rails ...or something
C body is close. C body wagon is same.
I have a C body housing at home. I can measure in the next few days. If correct width, I can throw in the truck and give it to out at Bonneville. I know thats not for a while, but still.
And a truck D60
