bOb shingler
let's see, you've upgraded the whole damn hotrod and the motor but not the stock fuel pump, DUH.
It seems to like the total number in the low 40's, not necessarily the initial number (harder to start).
Add some mechancial advance back into the distributor so you can keep the starter from straining and dial in the total timing it needs.
Have you jetted up at all?
What was the DA?
It's losing about 2-3 tenths in the first 330" which is probably the vac carb.
Nice work, it's coming around.
congratulations , you made it into the 12's !
No snubber, just (new) stock, rear shocks.
Well done a very enjoyable read and i'm assuming, your first foray into the 12's.
A cheap upgrade i did on my Dart was the 2" supersucker spacer, that netted me .15 and 1.5 mph and only cost me 60 dollars from Terry Walters performance but results can vary dependent on your combo.
Mick
Craigslist traction! start searching
I just have to look on the far side of my garage to find a pair of MT ET Drag Radials 255R-15. They just happen to be on a set of wheels that won't fit on the Dart and they are currently keeping this "other" car a roller. Even still I have been scoping Craigslist to see if someone was dumping some decent tires at the end of the season.
Quick check found out there are no "cheap" 15x8 rims with 5.25" offset I need to fit the back of my car...grrrr.
Congrats! Keep looking for rims,use the tires. That thread on the longer shocks with S/S springs, is good info.(Use a basic 18-22 dollar O Reilly's/Auto zone rear gas shock. Order for a 70-71 Chrysler Imperial)
