Name this part ... Whereas I have not a clue..
Mamabear
Member
Maine
65 barracuda. 318 engine.. thanks for any help to identify what it is..
As I'm not sure if
Is
necessary for running the car?
It looks like it was a starter relay. But where is the big stud that the battery + connects to? And yes, you need it!
Here's a few more pictures of the location of.
I'm thankful for your help with.. Hope this is more helpful to anyone as seeing the full placement of the starter relay as to the left of the harness connection point.. the part I need to replace is to the right of.. in the empty spot above the master cylinder
I believe it is a horn relay, does your horn work?
It actually doesn't
Factory one
Never has since I owned the car..
I only got concerned about the relay when I saw the broken off connector..
Didn't dare even turn the key
Whereas protect and respect..
Thank you for the welcoming
I'm looking forward to being a part of the forum and sharing experiences, of course ☺
