narrowed 8-3/4 question
fishy68
Tyr Fryr's Inc.
Central, IL (Hooterville)
Got a question for you guys that have narrowed a 8-3/4. A buddy of mine is about to narrow one 3" on each side and we need to know if we can still use the stock seals and bearings or do we need to go to the green bearings? I'm thinking since 3" will be cut off the end the inner seal won't be able to be re-installed cause I think it has a lip inside the housing it drives up against but I may be wrong. I have a complete set of new stock type Timken bearings and Nat'l seals we'd like to use but just need to know if they'll work.
Thanks, Tracy
i had one narrowed 2 inches on each side, the shop reused the ends. I just used stock seals but the new axles had green bearing.
Thanks for the reply AAR. I never thought about that but if they do the same on his it should be like stock so the stock seals will still work.
