65_valiant
Looking at this rear end for my 65 valiant. something i should buy? or pass? I'd have to relocate the springs as my car is 100% stock in that area.
here is what the guy sent me:
something you would buy? and if so what would you pay?
Seller said:Narrowed 8 3/4 mopar rearend cut down for an A body with a three inch relocation spring kit. End to end is 47 1/2 inches,center to center of the saddles is 36 inches. Axles are cut and have 30 splines, Axles have new rear axle bearing set that eliminates the production bearing retainer and axle end-play adjuster. 3 inch brake drums with new brake pads, spring retainer kits and new brake cylinders. Open 3.23 gear housing.
