forced 340
hey all. i am kicking around the idea about narrowing my 8.75. has anyone done this on here? i have dr. diff axles and rear disc brakes. any info would be great! thanks!
What is a stock one measure?
This is close to the worst advice I have ever seenCut tubes with big pipe cutter, itll cut them straight if they are round. Cut and respline axles. Install axles with new ends bolted up and use them as a welding guide. tack Weld new ends on, remove axles finish welds grind and paint. Install shock plates loose over unwelded perches, get pinion angle set and weld perches in place.
