After battling the flu the last few days I got out to try and start the Demon for the first time.
Nothing but bad luck.
First, I can't get any power at the key. Nada, Nothing. I check the wires and everything looks good. I even tried the neutral safety switch on the tranny. There is lots of power, as I crossed the solonoid and the starter kicked in no problem. The entire dash is not in the car, but I didn't think I needed everything. All the main plugin connectors are together at the firewall and at the steering column.
Second, While I was tracing down wires, I notice a water leak at the point where the block,head and intake meet. This one I can fix, it is hopefully a dried out gasket.
Other than that, no leaks so far.
I could really use some suggestions on the electrical end though. I don't know anything about electrical other than to hook a red wire to a red wire and follow directions.
Help please!!!!!
Jack
Help please!!!!!
Jack
