Need a little help
321Scamp
Indiana
I am needing some help identifying what car/s that this console could fit. Going to be putting it on ebay, but need to get the description right before i do so. What you think? ....
Maube 1966 or 67 Charger with that arm rest. Is there any cracks in the plastic? What is the part number? (look hard for it) If it is a 4-speed console it is worth way more, condition is everything.
On the outside, there is nothing wrong at all with the plastic, just needs to be cleaned. All the chrome trim is very good, again just needs cleaned. The lights covers are not broke and the wiring harness with bulbs are still in it. The only things i see wrong with it is that the plastic brace on the inside, under the shifter bezel, is broken off, arm rest needs recovered, and some one put a cheap hinge on it as well.
I found the a part number:
2788366
DPMC
AACX CAV NO 1​
