g49bridges
Hey guys, my knowledge on electrical is somewhat limited, so I need a little advice here. Working on my 74 small block Duster, which is far from factory. I've switched to an msd pro billet dist and blaster coil. Been running this set up since last fall with no issues at all. This past weekend I decided to add a 6AL-2 ignition box. Double and triple checked that everything in hooked up right, even called MSD tech line and made sure everything was right. The car starts up and runs great, no run-on or anything. But, as soon as I hooked it all up the ammeter goes to 3/4 full charge at anything over idle. lights flicker, etc. I went to the parts store and got a new regulator, changed it out, and now it's even worse...going 100% full charge at anything over idle. Swapped them back and same as before, 3/4 full charge. Checked the battery with the car off and I get 12.3v. With the limited knowledge I have on electrical, this is where I'm lost. No idea where to go or what to check next. Anybody have any idea on this?
