In short, I vote for the Edelbrock AVS style carb, but read on;
I noticed you mentioned something about running lean, which has nothing to do with carb size by tit does have everything to do with how the carb is jetted. So, any carb could run rich or lean, it's not size dependent.
A vaccum secondary carb has smoother transitions into the secondaries. A DP can be abrupt. (Not that it's a bad thing.) It should also have an edge on mileage, but that is also driver dependent. Lead foot or not.
Considering the 3.23 gears w/an overdrive trans, I myself would go for a 650 cfm carb. Maker? Your choice. I myself like the AVS style carb or TQ. Tuning them is key!
Tuning a TQ can be hard sometimes. Parts are not on the corner store shelf. I use home bent AFB rods to tune them if need be. But the nice thing is, the Performer will accept the TQ, no problem.
The smaller carb will only give up a minor and I really mean minor amount of HP only seen in the upper RPM range vs a bigger carb. (the 750 ) and no one would ever feel it or notice it unless your at a track being timed.
It will give you a better throttle response due to the smaller primaries and the higher velocity through them. This is an excellent "Pro" for mileage and giddy up and go off the line.
