aengineguy
Please help me choose a new different carb. Problem is that I have a Holley 750 HP, which has no choke and it takes about 3 starts to get it warmed enough to keep it running good. After about 2 minutes its fine and I am very happy with it. I would like to stay with the performance, mainly street at this time. I am pondering a Holley 870 Street Avenger (vacuum secondaries and choke), but don't want to serious diminish the instant response I have now, i.e. vacuum secondaries. Here are my specs....
Thanks for your input!!
1971 Dart Swinger with 408
Edelbrock Magnum Heads fully CNC ported by Hughes, 2.08" intakes, milled back to 58cc chambers. Around 300 cfm @ .600 lift
10.65 static compression
Hughes Solid Camshaft
Intake Lift .610
Exhaust Lift .614
Intake Duration @ .050 valve lift 252
Exhaust Duration @ .050 valve lift 256
106 degrees Lobe separation angle
Port matched Edelbrock Air gap Intake
750 HP Holley double pump Carb
TTI Industries 1 7/8 Headers
TTI Industries 3" dual exhaust with X pipe to the rear bumper
Mallory Magnetic Breakerless #42 Distributor
Mallory Hyfire 6AL Capacitive Discharge box with rev. limiter
Edelbrock 160 GPH pump
-8 AN lines to regulator and -6 AN to carb
John Cope built HD904 Torqueflight
Manual Shift Reverse Pattern
Kolene steels
Red Alto Clutches
PTC 3600 rpm torque converter
Moser 8 3/4 nodular center section with Richmond 4.10's and Moser Alloy axles
Should weigh around 3100-3200 with me
Intake Lift .610
Exhaust Lift .614
Kolene steels
Red Alto Clutches
