Need early-a v8 mount brackets and 318 flexplate
Rockerdude
Rock n' Roll and A-bodies
Arizona
Hey guys, I need a couple things to get the 318 ready to go into my wagon. A set of early-a v8 motor mount brackets and a 318/340 flexplate. Thanks!
I also need the throttle linkage and gas pedal from a 64-66 v8 car too. Let me know if you have anything please!
When I put the 360 4bbl in my 66 Dart,I used a 72 Duster gas peddle and throttle cable.Made things so much easier to work with.The 66 V8 gas peddle bracket is getting to be pretty scarce and if you find one,you,ll be paying.Try the upgrade,you,ll be glad you did.JMO.:D
Id rather it look original. Thanks for the tip though!
That's my old wagon! That thing will be sweet with a small block. I do have have the v8 motor mounts, and I am pretty sure I probably have the v8 gas pedal but I am not positive what it is supposed to look like lol. I have a pile of gas pedals that you are more than welcome to dig thru.
