need help cross referencing spark plug
duster360
Alabama
I have an autolite 3924 plug and would like to cross reference to ngk. Can anyone help? When I cross reference I came up with about 20 different ngk plugs.
Cross references are only a guide. You should check application on what you are going to use as well (NGK) and even then THAT is only a guide.
I can show you cases, "back in the day" when you could interchange from say, Champion to AC and back to Champion from AC and be several heat ranges off.
With my combo Edelbrock suggested the Autolite 3924? How did they come up with that number? I gave them all the info they asked for of the engine and that is the number they gave me.
edelbrock comes up with a plug that has 3/4" reach and 14mm thread gasket seat. they guess/average on heat range. I said throw some new plugs in.
Been using Autolite ar-3924's in my Edelbrocks for over 6 seasons now excellent plug..
