ok, so one of the brackets on the radiator got loose from the weld and the whole RAD went into the fan , cutting a bit into the rad causing a hole or holes in the rad . antifreeze shooting out alot . question one is , is this something that can be repaired by a rad repair shop ? and Q #2 is i stripped the head ( made it round ) on the brass fitting trying to get the trans line ( automatic ) off the radiator . but still is not off . so , what do i do now ? i was thinking of trying vice-grips ( since i am past the point of no return ) , any suggestions ???? also , would the repair shop or auto supply have a new brass fitting for this ?
car is 1972 dart 318 auto
