Need help reading fender tag
Stucker152
Active Member
Great falls
Can someone please decode my fender tag. I'm trying to figure out which transmission is in my 75 dart swinger. It has a 3spd auto on the column. But unsure if its a 727 or a 904?
VIN: LH23G58271806
Engine: E44 = 318 2 bbl
Transmission: D34 = 904 transmission
Scheduled Production Date: 519 = May 19th
Vehicle Order Number: 943873
Body Paint: LE9 = Vintage Red Metallic
Top Paint: V1L = Vinyl top Parchment color (off white)
Interior Trim: E2L3 - parchment (light and dark
Upper Door Frame Paint: 000 = full door panels
U -- Build To USA Specifications
B43 -- Manual Brakes
C15 -- Deluxe Belts
G52 -- manual left mirror
J52 -- Inside hood release
K5X -- body side molding w/vinyl insert black
L31 -- Fender Mounted Turn Signals
L73 -- S/Belt Lamp
M21 -- Roof drip moldings
M25 -- Wide Sill Molding
M26 -- Wheel Lip Molding
M38 -- Deck Lid Finish Panel
N37 -- Catalytic Exhaust System
R11 -- AM Radio
L1 -- cloth and vinyl Bench seat with headrests
702 --
It was never changed. I'm the third owner. And the car was in my family it's entire life and only has 14k original miles.
ok so its a 904. checked the pan last night. How do you tell what size rear end? (7 3/4, 8 1/4, etc.) also how do you tell what gears are in the rear end?
Do you have the broadcast sheet?
otherwise as posted, "spotters guide".
To check ratio on the fly,
if open rear, jack up one side and turn the tire one full revolution and count how many times the pinion turns.
If sure grip same as above but have both rear wheels off the ground.
If it turns just more than 4 times 4.10
less than 3 time 2.70, 2.90 etc...
Or count the ring gear teeth and pinion gear teeth and divide R/P. 41 tooth ring gear and a 10 tooth pinion gear 41/10 = 4.10
sometimes there is a tag on one of the cover/mounting bolts that gives the ratio.
