Need help with fan/clutch I.D.
smlveightis
Confused in Confusion
Westland-Meechigan
I found a fan/clutch assembly in like new condition. It has #2863-216 stamped on the fan blades. Was wondering if it would fit my 273? Any help would be very appreciated.
That number comes back to ..............
18 & 1/2 inch 7 blade fan
Used on..
68-71 B-Body 383 or 440 with Max Cooling and A/C
69-71 Fury, Polara and Monaco, all V8s with A/C
70-73 E-Body with 340 or Hemi..no A/C
73 A and E Body with 318 or 340 with A/C
73 Charger,Coronet,Satellite, Fury, Monaco and Polara with 318 with 2.94 and A/C
73 Fury,Polara and Monaco Taxi or Police Car with 360
Just make sure your radiator is wide enuff... 22 or 26 inch.
And use a shroud.
Thanks a million, yellowdartdave!! The guy I want to but it from says it wouldn't fit my car. I tried to tell him that most of the fans/clutches are mostly interchangable, but he wasn't going to listen. I'm running a Griffin aluminum rad, and plan to fab up a shroud, once fan is installed.
