Need picture of alternator mounting points
71ABODY
Member
I am putting a 68 Dart GTS 340 back together. Some of the disassembly I did not do. Would someone be able to provide a picture of which bolts on the water pump the alternator brackets attach to. I have tried several ways, but there is a treaded hole in a flange that extends out beyond the two water pump bolts, that it should mount on. The car has no A/C nor P/S. Please help!
Thank You. What year engine is this? My 68 engine has the smaller water pump on it.
