snapetwo
Ok so I pressed new bushings it, redid the one I pressed to far.
Figured a out a way to take the inner sleeve off the pivot arm, welded a pair of vice grips to it and pressed, ha worked great.
So the lca. First i had to stop at 3am, but I was trying to install the passenger side lca, and the damn tb adjuster "bar" that attaches to the tb socket kept turning when I was tightening the pivot arm nut, then getting stuck on the frame rail. Then I realized I forgot to attach the strut bar and had to pull it all off.
When i take another wack at this tomorrow, is there a better way to do it? Manual days I gotta get everything back together including tb's, discs, wheels, etc.....
Thanks.
Ps driver side pivot arm is missing washer, gonna try to find a few at ace hardware to use in place, anyone see any issues?
Thanks.
