lawman340
I have a 72 Scamp that I just bought and the engine wiring harness is a mess I've been using the links below and pretty much have it all rewired except with one exception. On the diagrams it shows a dark green with red stripe wire coming from the engine harness plug and going to the horns and on the light harness it shows a dark green wire with red strip going to the starter relay. My light harness was untouched and still factory and it has the green with red stripe but instead of going to the starter relay it's going to the horn. My engine harness had been cut and spliced so many times the green wire was soldered in a mess with several others. It was a factory electronic ignition but it now has the HEI style distributor in it...is it possible the diagrams are wrong?? Help!!!
http://www.mymopar.com/downloads/1972/72DartA.JPG
http://www.mymopar.com/downloads/1972/72DartB.JPG
