73 Plymouth Duster
So I am having problems with my Duster dying due to fuel issues (another whole topic on here) but the bigger problem is when I can't get it started at a light because the neutral safety switch wont "engage" after going from park to neutral and wiggling the shifter around (on my 727) I can eventually get it to start (wort time was 30 sec until I got it)
When I got home to diagnose my other fuel problem I tried to start it after about 5 min once I had turned it off and it fired no problem. I shut it off and tried it in neutral and no problem. Looked under the car the wires look good, it was plugged in tight so I am assuming I can just go throw another switch in my tranny? Is this a common way they fail?
Thanks in advance!
Thanks in advance!
