1966Post
New never used 340 grind camshaft. Bought this 12 years ago from Northern Auto for an engine build I believe it was a Speed Pro brand .429/.444 lift. Per the feedback posted today this was probably ground off a better quality core blank back then. $110 plus actual shipping/mailing cost. No rust, that is old Lubriplate on the journals Check Summitt 6920 if you need more cam specs Thanks FABO
