New big block
earthmover
in the tire smoke
nc
400 block push out to 505
440 1 heads big valves td rockets heads cleaned up
Custom cam for the combo and nos
Ohio 8 bolt crank rods
Block oring and studded
1050 dominator
Vacuum pump
727 reverse pattern
8 inch 5500 turbo action vera
Aluminum both thru 9inch 456 gear
Squard tube chassis
Fiberglass frontend
Fiberglass doors
Fiberglass deck lid
Fiberglass bumper
Lexan windows
Aluminum interior
14/32 mt
Any guess on hp
And time in 1/8 miles
Hard to say without knowing the details. If the secret custom cam turns out to be a Mopar 509 then it isn't going to be making much power. If the chassis work was done by a blind squirrel then the car won't make it down the track.
Any thoughts on the cam specs
Everybody wanted the generic cam lol
Whats the compression and weight and how much work has been done to the 440-1 heads? If you have the flow numbers, then it’s a matter of plugging the data into one of the available horsepower calculators online. Plugging the weight, gear, and available hp into an eighth mile will get you fairly close to what the car may be able to run. As DodgeDifferent stated, expect to be below this figure and having to do a lot of tuning to get close to your target. Also, keep in mind accuracy information you get out of the calculators is dependent on the accuracy of the numbers plugged in (remember, garbage in = garbage out) and that the time/mph calculators are based on the car having a pile of traction. Good luck sorting everything out and keeping it off the retaining walls! This build may not actually live up to its potential without a power glide and a lower rear gear to keep the car over loading the tires/rear suspension/wheelie bars off the line.
Been a while what are you guys running for timing on this motors ..ill try and post up a video of old thing running
Mine is more street oreintated , but 24 initial , and 34 @3000 , 93 pump gas ------think Andy is running 25 initial --??
