tom340
I'm set for this year, just gonna enjoy the added performance of the TTI headers....... but I'm planning ahead already for the next step.
as is now : Fresh 372" balanced stroker motor. Less than 5,000 mi. since rebuild. Using 308 heads, valves upgraded to the 2.02's. Currently no porting, they flow tested real well (as is). KB forged pistons, I believe they are 10.5:1 and the machinist used #051 head gaskets to get me down to about 9.9:1 to use with a fairly mild cam. The cam now is .500 lift, 226/230 dur at .050" and 112 lobe seperation angle. Also using 1.5 roller rockers. I thought about swapping in a more aggresive hydraulic just for this summer but didnt want to pull heads for thinner gaskets to bump compression, so just gonna be patient and do all at once.
No tuning on the dyno- they pulled 428hp and just under 450 ft. lbs tq. No timing adjustments, 650 Eddy Thunder carb right out of box. Also they had to use small tube Chevy headers 1 5/8- as the plan was for me to use the manifolds until I had more mad $$ for the tti's. Lennys Ultimate 10" converter (3800 stall) and tti's finaly installed the car runs really strong. (converter is loose-built for planned modifications)
Ran at Lebanon (with manifolds-street tires-3.55's) and was doing 106-107mph trap speeds. That was 2 summers ago, huge difference now with the tti's!!
The plan-
Have the 308's stage II ported, and also port match the edelbrock performer rpm intake. This isnt now, or going to be a race only car. Street /strip, not looking to go radical. Not seeking to max out a low ET, just wishing to increase @ 60-70 HP over the current setup with head work and cam. Want to be able to go low 12's, keep it reliable for street. Some homework on camshafts and compression ratio needed. Mostly how much to bump compression ratio for a longer duration cam to get the most from it.
My "thoughts" are something like Hughes .540-.548, 232/237 and 110 with someting close to 10.5:1. Leaning towards a roller cam.
Would love to hear ideas
The plan-
